I have captured a video from my Sony Digital8 camcorder, but I am getting an error when I try to load it into Virtualdub.
The error says: Couldn't locate decompressor for format 'dvsd' (unknown)
What application do I need to use to capture with so I can use Virtualdub on the file? I have tried Windows Movie Maker 2, Roxio Videowave, and Ulead DVD Movie Factory 2 to capture and Virtualdub gives them all the same error.
Thanks for all advice.
You need a DV codec. Check the Tools section at left.
Hello. -
the main concept and panasonic dv codec will work
Problem with opening AC3 in VirtualDub
By andy_blah in forum AudioReplies: 5Last Post: 6th Nov 2012, 17:25 -
Virtualdub opening H264 encoded file
By tvbear in forum EditingReplies: 0Last Post: 26th Dec 2011, 07:22 -
VirtualDub, problem with *.ts opening
By UMO in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2010, 16:50 -
Problem opening Xvid movies in VirtualDub
By wombat4 in forum SubtitleReplies: 9Last Post: 24th Jun 2009, 10:23 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 11:53
