Results 1 to 12 of 12
  1. I want a software that will allow straight burns. Just like if you had a cd, pop it in and make a straight burn to the blank cd in the other drive. I want to do this with DVDs.
    I actually found some better answers. Which of these would be the absolute best program for ease of use and keeping all the features?
    http://www.dvdxcopy.com/
    Mar 2003
    Kansas City MO
    No offense, but straight burns. Yes DVDXCopy Express will do that and so will DVDXCopy Platinum which gives you more control. Yes thes are simple programs, but I thing DVD Shrink is even better. More control and its free. But I get the feeling you don't want to do a lot of work so you better just buy DVD XCopy Express. Gives you the options of just movie or entire disk.
    Dec 2002
    The Great Northwest
    Another One button'er.
    Pinnacle Instant Copy 8, slightly more than a one button but fairly a brainless approach and worth the time in quality vs DVDShrink, DVD2one and all the others you one clicker seem to like so much, IMHO.
    Hell we all want something
    For real DVD BU Quality.
    The Big Three
    or
    DVD2DVD
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  4. Member tumbar's Avatar
    My personal choice is anydvd/clonedvd.
    This option allows me to use a dvd read drive and a dvd write drive, making the decrypting to hard drive step unnecessary.
    By setting dvdclone to preserve menu and only choosing the movie titleset, I have acheived my goal of "menu/movie-only" backup, in a one button setup.
    Jim
    Jim
  5. Banned
    May 2003
    Massachusetts
    The problem here is that a good number of DVD's won't FIT on a DVD-R.
    You have two or more steps needed to copy a disc.
    1. Ripping.
    2. Shrinkage (if necessary).
    3. Burning.
    Now, step 3 can be done with any ol' program (I just don't recommend Nero since many versions of it give many people problems with DVD Video). Step 1 can be done by a standalone program or as part of whatever tool you use to do steps 2 and 3.
    If you have a DVD5 disc, which means it'll fit on a blank with no compression or anything, you can use DVD Decrypter to copy the disc. End of story, and it's free. Alternatives are AnyDVD, SmartRipper, etc.
    If you have a DVD9 disc, you'll need to shrink the movie some. This gets complex, and many people have different opinions. May I suggest you READ some of the old posts and guides? Hmm?
    - Gurm
    Mar 2003
    Uranus
    I want , I want .
    Sep 2003
    USA, MN
    The Big Three
    or
    DVD2DVD
    I was going to go with the big three once untill i relised how much DVDMaestro and/or Scenarist NT cost. Just to backup up some of my dvd's the price seemed a little high.
  8. Banned
    May 2003
    Massachusetts
    ROFL. A "little" high?
    - Gurm
    Sep 2003
    USA, MN
    Ok mabey I worded that wrong, "way out of my price range just for simple backups"
  10. Yeah, I am not sure which is the best way to go. Maybe I should wait a little longer and wait for prices to drop.
    Jul 2003
    DVD Shrink 3.0 ALL THE WAY!!!!!!!!!!!!
  12. Banned
    May 2003
    Massachusetts
    Prices on Scenarist will NEVER be affordable. $30k is a bit excessive. Even $10k is ... um ... absurd.
    Let's leave the debate about Scenarist out of this thread, it inevitably devolves into some of us saying that "The Big 3" is essentially an attempt to legitimize piracy... and others getting ALL bent out of shape over it.
    - Gurm
