So I want to transfer the old Spidey TV show to DVD and I have all the original store bought tapes which are now out of print. I figure the tapes are over 10 years old so the quality is starting to degrade so maybe I'll transfer them to DVD. Is there any advantage to capturing at 720 X 480 like the guides suggest? I mean correct me if I'm wrong, but isn't the actual resolution less than that since it is a VHS tape? What would the benefit be? The sound I can sort of understand capturing at CD quality, even though it's mono but what should I capture the video at? Any help is appreciated.
lots of people will tell you not to capture at DVD resolution (720x480), because it's a waste of space and VHS resolution is not that high. They will suggest you capture in 1/2 D1 (352x480), as it will look as good at 4K bitrate as Full D1 looks at 8K bitrate.
I would suggest you take a VHS tape with a good, crisp image on it, capture an identical 30 second - 1 minute clip of it in both resolutions, put them on a dvd-rw and see how they look on your tv. You may not see a difference - I saw enough of a loss of detail and sharpness in the 1/2 D1 version that I capture everything in full D1 resolution.
but let your eyes be the judge - it'll take all of 15 minutes to get a test disc ready to view. If you don't see a significant difference, go for the 1/2 D1, you'll fit more material on a disc.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 12:18 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 02:10 -
Higher resolution sizes than 720x480 on MeGUI?
By Umandsf in forum Video ConversionReplies: 2Last Post: 4th Apr 2010, 08:10 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38 -
How to convert DVD to mkv with 720P or higher resolution
By dharmesh13 in forum DVD RippingReplies: 2Last Post: 21st Apr 2009, 20:47
