Ive read the guide located here:
http://users.skynet.be/contra/dvddouble.htm
Ive had no problems going this way, but ive got a couple of DVDs with 2 audio tracks, one in English and one in Japanese, how can I keep both audio tracks for both movies on one DVD-R ?
Tmpegenc only wants to select one audio track when i would like 2.
Some suggestions would be great thanks!
Hello HamishT.
I'd suggest DVD Shrink v3.0 beta 5.
http://www.dvdshrink.info/guides.php
Read all the guides if you're not familiar with DVD Shrink.
Only the v3.0 beta 5 guides if you are. -
You're welcome.
Tmpgenc dvd author will not allow you to mix formats ie PAL and NSTC.
DVD shrink does allow you todo this. Then use your favourite piece of software to reduce resulting vob files to fix on one dvdr.
dlb.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
