I've followed the guide on putting vcd to dvd for ulead. I don't want to reconvert the mpgs, and I follow all the instructions. I have it checked not to convert compliant mpgs. These vcds are NTSC compliant. Every time I output, it says it's converting videos. I check the finish product and I do notice a change in video quality. Am I missing something?
Always click the second button from the left in the lower left corner of the interface (the button with the CHECK) immediately prior to the burn.Originally Posted by snek11
Make certain your Ulead DVD MovieFactory 2 project settings match the properties of your source video.
Also, there is a new patch now available at the following link...
http://www.ulead.com/tech/dmf/dmf_ftp.htm
...for Ulead DVD MovieFactory 2.
Hope this helps,
Jerry Jones
http://www.jonesgroup.net -
Thanks for the reply. Do you mean in the Project settings, Change MPEG Settings, General tab- switch it from 720 to 352? I didn't see this step in the guide on here. I thought it shouldn't matter since it wasn't suppose to be reconverted. I'll give it a try though thanks!
MP4Cam2AVI converts my video to slow motion
By sozuki in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 18:31 -
converts to dvd but its always to big
By dylanvega123 in forum Video ConversionReplies: 3Last Post: 5th Aug 2009, 18:53 -
.MOD to AVI - video converts, but audio doesn't
By bball101 in forum ffmpegX general discussionReplies: 1Last Post: 3rd Sep 2008, 13:43 -
Gotsent..converts to where?
By macman89 in forum Video ConversionReplies: 0Last Post: 24th Jul 2008, 19:16 -
what software converts to DVD with manual video bitrate control
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 13:09
