I know that TV signal is interlacced, and that deinterlacing algorithms pratically join the 2 fields in one. So IS IT BETTER TO CAPTURE AN HALF SIZE VIDEO (and then resize it) OR CAPTURE A FULL SIZE INTERLACED VIDEO (and deinterlace it)? THANKS
Guest
Depends whether you want to play it on a PC only. If you still want to play on a TV set, you'll need to keep it interlaced.
Full size means more information and thus better quality (for both interlaced and non-interlaced)
cheers
Leo
Equipment:
Athlon 1700 XP system
512 Mb RAM
Geforce 3 Ti500 64mb
1x 100 Gb hard disc (IDE)
1x 40 Gb hard disc (IDE)
1x 40 Gb hard disc (firewire) -
Whether you want to play it on a PC or not ( No offense Leo
) it's better to capture at the largest size possible and de-interlace and reduce. A standard TV picture is actually 2 frames interlaced so, if you only capture quarter resolution, you can miss a whole lot of detail.
Get hold of the 'smart de-interlacer' filter for VirtualDub. This does a great job of it on the default settings.
Mind you, having put in all the guff above, it also depends whether your hardware can handle the larger size and the higher data rate. If it can't and you're getting heaps of frame drops, stick with the best it can do. No point missing large chunks to get a bit of extra frame detail.
Best bet, have a play with it and see what gives results you like.
My personal settings are to capture at 352x576 ( half PAL ), smart de-interlace, 2-1 vertical reduction and serve to TMPEG on standard VCD. Very watchable on a 51 cm TV.
Have fun,
Ian -
The vertical 2:1 reduction can be done during capture, so no deinterlacing is needed. Also, you save a lot of disk space by doing vertical reduction during capture instead of after capture.
VHS Capture Size Massive?
By donkey33 in forum Capturing and VCRReplies: 17Last Post: 24th Feb 2011, 01:40 -
Size to Capture VHS at for DVD
By MasterOfPuppets in forum Capturing and VCRReplies: 4Last Post: 3rd Mar 2010, 17:15 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 16:46 -
Window size of video capture too small
By rapattack in forum Capturing and VCRReplies: 2Last Post: 16th May 2008, 09:38 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 12:34
