I am trying to record various (3 or 4) VCD quality movies on a single DVD but even though MovieFactory alloe me to decrease video quality I am having problems with audio and other pains.
Any idea tom help me ? Roxio Easy DVD makes them so big that tehy fill a DVD each one.
Thanks : Mauro![]()
use tmpenc to make them dvd compliant, you must change the audio to 48000. use tempgenc author to create dvd folder.
Sounds like two things are happening. First mp2 audio is NOT supported by the DVD Standard. So your program is converting the audio to PCM (uncompressed wav) which is supported. That's going to results in huge files. There are a lot of ways to do this (can't find guide to link to) but:
1. If you don't already have the MPEG1 files, use VCD Gear (or other program) to generat them from the VCD dat files.
2. De-mux MPEG1 files into m1v and mp2 files
3. Re-encode edit from 44.1 khz to 48khz, either mp2 or to ac3:
http://www.doom9.org/audio-guides.htm
4. Author DVD using m1v and new 48khz audio files. Author from elementary streams, no need to mux anything (that's the authoring programs job).
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 09:33 -
SEARCHING: DVD Software WITHOUT re-encoding MPEGs
By jouse. in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2010, 04:57 -
Portable APP to save mpegs from a DVD?
By bigMach™ in forum DVD RippingReplies: 2Last Post: 12th Nov 2009, 08:07 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 12:30 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 02:01
