Hi-
I have an mpeg that I took from a commercial DVD using DVD Decrypter. I can play it OK on the PC, and can put it on a DVD & play it in my DVD player with no problem.
I want to remove about 60 seconds of material at the end of the file, but every time I do so, the resulting mpeg has no audio. I've used both Video Studio 7 and TMPGenc. All goes well with the cutting & saving, but no audio.
Am I overlooking something simple, trying to do something that's impossible, or??
I've done this with DV AVI's captured from an ADVC-100 with good results, but this is the first mpeg I've tried to edit.
Thanks!
WOMBLE MPEG2VCR.
Visit lordsmurf.com for guides (commercial removal).Want my help? Ask here! (not via PM!)
Thanks Lordsmurf; although I didn't try MPEG2VCR, I did read your Commercial Removal guide, and made note of your comment that TMPGenc sometimes has difficulty with an mpeg, and that the problem can be solved by removing a few seconds from the beginning & end of the clip & saving as a new mpeg. I did that with my problem file, and it seems to have worked! Before, I had only been removing material at the end, and as I mentioned, the result was the video I wanted, but w/o sound. This time, I removed 2 frames from the start in addition to the footage I wanted to remove at the end, and everything worked fine.
Thanks again! -
So what are the problems with tmpgenc, and what is your method ?
How to remove ads from MPG?
By lovelylisa in forum Newbie / General discussionsReplies: 8Last Post: 28th Jan 2012, 06:15 -
easy way to remove alpha logos (with no opaque parts)
By dumbledore in forum EditingReplies: 1Last Post: 16th Feb 2010, 18:22 -
Remove certain parts from MPEG-2 [no transcoding]?
By therock003 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 13:49 -
how to edit/manipulate .exe files to remove parts?
By Xylob the Destroyer in forum ComputerReplies: 5Last Post: 8th Nov 2008, 14:56 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 13:38
