I am encoding dozens of AVI files with DIVX at very high quality but each one is going to take around 14 hours to complete.
Is there any software that can save the progress of the encoding which will allow me to power down the computer and power back up to resume encoding?
Cheers.
jaffy
TMPGEnc. Set up your encode, save the template. Begin your encode, stop when you want. Note where the encoded video has ended. Load the source video again if it is not already loaded. Load your saved template. Go to Settings-->Advanced tab-->Source Range. Set the start frame where your finished video ended. Select the end frame. Select OK. Rename the end file, to keep from having to redo your previous video. Start your encode to continue where you left off.
Repeat until all your videos have been compiled. Since you used the same template, you should have no problems merging them.Hello. -
I had that idea too. But the problem is in Source Range they show the number of frames as if it is a 30fps movie. But I'm encoding at 23.976fps, so the frame where I stopped will not be the same as in the frame in the Source Range. Any other ideas?
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 06:21 -
IE7- How to select Save as type and Encoding when saving Webpage?
By coody in forum ComputerReplies: 3Last Post: 9th Jun 2009, 14:49 -
Help with Camera, Capture, Encoding, and Saving.
By shane123 in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2009, 21:24 -
MISSING PROGRESS.APP hence the encoding doesnt continue
By drevinko in forum DVD RippingReplies: 1Last Post: 26th Feb 2008, 22:17
