  1. What is the best thing to do with a multisession when burning a dvd? Start a mutlisession or no multisession?? does it matter??? im using DVD+rs. it works fine in mine but it has trouble in a friends, but the +rw worked fine???...SasArchiver
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
  2. Hello again, Sasarchiver.
    You have to select "No Multisession", whether you're writting to DVD-R or RW.
    You'll still be able to erase the DVD-RW.
    Check some of the burning guides here, and at http://www.dvdshrink.info/guides.php
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  3. No Multi session for movies, but if you are adding data to a dvdr, it can be used and is quite useful.
    The only proviso is that the PC's must be running XP, to be able to read it properly.
  4. ok guys, cheers once again for ur help, must appreciated...sasArchiver
