  1. I am having a problem with ifoedit. i'm trying to mux an ac3 and an m2v file with an audio delay and, for some reason, my video_ts folders are all coming out only with video and no sound. i tried to do it without the audio delay to see if that was the problem, but the same thing was happening. is there something wrong with my ac3 file or is there something i may have forgotten to do? is there another program (for mac or pc) that can mux files into an img or ac3 file and allow you to have an audio delay?
    yes, i posted this in another forum but i don't think it was meant to be there. i am a stupid newbie.
    Apr 2002
    The State of Frustration
    I remember reading the how to guide involving IfoEdit. It seemed IfoEdit wants the .mpa file suffix. Have you used AC3 in IfoEdit before?
    Hello.
  3. yes, i used it before, but this particular ac3 is mono, not 5.1. maybe that has something to do with it. if i change the file extension from ac3 to mpa, do you think it might work?
    Apr 2002
    If not having AC3 does not matter to you, you can always convert it a wave file, HeadAC3.
    Hello.
