I am trying to make DVD's after capturing from pinnacle miro video dc30 capture card.
The card captures only around 640 (forgot precise resoultion) which is not DVD NTSC resolution.
After the capture I use the Tmpgenc to encode it to DVD mpeg 2 format.
Then I burned it using mysonicdvd. The problem I am having is that movie jitters when there is fast moving scene, it is kind of garbled for that moment. I had the similar problem while making SVCD but after using bbmpg before encoding the movie for alright.
So, do I need to use anyother software to resize the captured avi from miro dc 30 before using tmpgen to encode it. Any help is appreciated.
