Did you make sure that Full Processing was set on video and audio?
If that was set , I have no clue , I've never seen
Vdub fail to open it's own output.
Now this will seem crazy , you didn't close the first Vdub after
you started the frameserver did you. ? You have to leave it running
When I open a VDR without a running Vdub attached to it, I get the same error.
Results 31 to 39 of 39
It was Full Processing on both audio and video and it have keeped it running.
This really is strange
The really weird thing is that this movie is split into 2 files that are both XViD AC3 and I had no problem with the first part. -
Will the second part actually PLAY all the way through in Vdub ?
You may have to get VirtualDubMod or one that does AC3 -
I tried with VirtualDubMod, same error...
And theris no problem playing the seconed part.. just loading it.. -
I had this same problem with certain files try to frameserve and tmpg says "unrecognised or unsupported" though they're not neccesarily xvid i'm having probs with, I've only just this morning found a way around it so here it is.
First open your .avi in virtual dub and set video to direct stream copy (the audio settings don't seem to make a difference here, mine was AC3 so i already stripped it to a wav so was set no audio!) then choose "save old format avi" only takes a couple of minutes. Then open this new file with virtual dub and frameserve as normal adding whatever filters you need, should now open in tmpg without a problem!! I've tried this on 2 files I was having major issues with and it solved both!
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 16:16 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 19:09 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 08:44 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 04:26 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
