I have a XViD avi file with sound as AC3.
As far as I know, TMPGEnc cant load a Audio file that's AC3, so I took the sound apart from the movie and converted it to a WAV file.
After that I loaded the XViD movie with the WAV audio file and started the Frame Server. When trying to load the vdr with TMPGEnc it told me "can not open, or unsupported".
I have done this in the past with AC3 audio movies and had no problem...
Anyone got a clue ?
Thanks![]()
Results 1 to 30 of 39
Yes I am familiar with that site... I upped the priority up to 10 (!) and still the same message.
Should I refer to the the Frame Server section to ? because I have no probkem starting it. -
does it come up with an error saying' unsupported format'???
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
I would try to re-install the codec and be sure I had the most recent. I've had that problem before where it seems that the codec didn't get registered right for the direct show filters.
yep jtommys right, i had this problem i had to uninsatll all my codecs and tmpg and reinstall them and it work.....SasArchiver
what codecs u using lol....welll i use lsx mpeg3 encder, divx fast/low compression (didvx 5.0.5). you unistall them from add or remove programs, but afterwards u should maybe go through ur program files to make sure it deleted the folders and files....I'm thinking here, but xvid might be different from divx but i dont put a sound fomat in, it doesnt need it, you just select ur output and start. i might be wrong in ur case...hope u conquer this terrible affliction lol...sasArchiver
OK- Sometimes there's a quirk with a .vdr file loading into frameserver mode that doesn't have audio. Here's what you do. Load the ORIGINAL xvid movie file into Vdub. Start your frameserver and save your ***.vdr file. Open this vdr file in the video input and your .wav file in the audio input of TMPGenc and see if that works for you.
Dont uninstall your codecs. -
I reinstalled the codecs and tried what jtommyj said and still the same messeg...
Did you set-up the frameserver handler in VDub ? Go to Aux set-up and install. You need to have this to get frameserver to work.
reboot .... reboot.... reboot .. after all install/de-install !!
I have rebooted and the handler is installed.
But if the frameserver starts what can be wrong ?The frameserver isn't set up correctly -
When you set up your frameserver, are you choosing uncompressed in the video compression options ?
Yes, thats what I meant. Does the frameserver work with any other file ?
Yes...
I'll try to reinstall VD and TMPGnc.
I see they have no uninstall opiton so is it enough to just delete the folder their in ? -
There's no point to un-installing if other files can be frameserved. It wouldn't work at all if it was a VDub or Tmpgenc problem.
If you just load the .avi file into Vdub and then try to convert to another codec (ie Divx, Cinepak, or whatever), does that work ? -
Look what I did;
I loaded into TMPGEnc the XViD into the Video Source and the WAV for the audio source.
Converted it into a SVCD. Every thing was fine.
Now, I loaded the SVCD into VD, and without touching (add any filters) it at all I started the framservere and when loading it into TMPGEnc I got the same messge !
So what can be wrong ??? a minute ago TMPGEnc conveted it into SVCD and now he cant load it ??? -
Well ?Did you set-up the frameserver handler in VDub ? Go to Aux set-up and install. You need to have this to get frameserver to work.
tmpgenc cant handle mpeg2 as input (your svcd file) it converts other formats (xvid) to mpeg1 or mpeg2
However you can fool tmpgenc into accepting mpeg2 as input if you frameserve using virtualdub.
WHY dou you want to run the SVCD file thru tmpgenc (2nd time) anyway?? this makes no sense.. use your original files for input and adjust the parameters (output size too big??) lower the average bitrate.Corned beef is now made to a higher standard than at any time in history.
Originally Posted by FOOI dont want to run the SVCD again into TMPGnc. I wanted to load the SVCD into VD, make the changes and then framserver to TMPGnc (i thought if i would convert the XViD it into a mpg TMPGnc would get it) But I got the same error.I have rebooted and the handler is installed.
Anyone have any other suggestion ?
Thank you all for tring to help. -
As others have suggested reinstall the V-Dub handler. Go to auxsetup and click on it. Then click on install handler. Then go to TMPG and in the environmental settings and make sure the Direct Show Multimedia File Reader has a priority of one or two (no need to make it 10). Then try to frameserve your xvid avi with the wav file. It should work. Honest.
I would suggest the following experiment
Start Vdub abd load your file. Set Full processing mode for
audio and video.
start frameserver
Open the VDR signpost file with another instance of Vdub
See what the video information says.
If that works and reports uncompressed video and PCM audio,
then the problem is with TMPGenc frameclient setup. -
Not all versions of VDub can handle MPEG-2 whick is what a SVCD is. Make sure you have the MPEG-2 version or it won't accept the SVCD file.Originally Posted by Somebla
jtommyj, I have Vdub with mpeg-2 support. the problem wasnt loading the file but loading the framserver of that file with TMPGnc.
FOO, I made a frameserver of the XViD, then loaded the vdr with another Vdub and got this error:
"Cannot determine file type "e:\..""
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 20:09 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 05:26 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 19:26
