  1. i use winXP pro.
    premiere 6.5
    latest TMPGEnc.
    and i use avisynth v1.0 beta31 plugin for frameserve to tmpgenc.
    in the final result VCD or SVCD video is ok (well,no so good quality)
    but there is no audio.
    all settings are double checked and ok,
    what can cause this problem??
    rgrds
    ps: the source video is avi PICVideo MJPEG with PCM audio 48khz sample rate.
  2. So what's the problem? If the video is OK, everything is OK. Just extract the audio, encode it separately and mux it with video. Problem solved.
