I have a DVD player that plays VCDs, as I have a bunch that I've boughten.
I burn a VCD with Nero, and it works fine on the computer, and the format is EXACTLY the same way as the CDs I bought... But it doesn't work in anything BUT my computer. I tried different CD brands, but all the same thing, even after the videos are converted to MPEG2. What in the crap am I doing wrong?
-usslindstrom@hotmail.com
Check the DVD Players list to the right to make sure that you DVD can read CDR discs. As a test you might want to make an audio disc and see if it can read/play that?
If it can't then your DVD player can't read CDR (or that brand). If it can, then report back what software/settings you used to make the MPEG file, how you burned it, error message from DVD player, etc. etc.
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
