This drives me nuts, on some files you are not alowed to edit (i.e. copy) the video track in QuickTime. Why is this and is there a way around it?
You can't edit MPEG1s at all. What you have to do is use bbDEMUX to seperate the audio and video tracks, convert the audio into AIFF, and the video into .MOV (I'm testing using MPEG4 for editing, and so far it works, and I've heard you can also use DV).
Stupidity is like nuclear power, it can be used for good and evil-and you don't want to get any on you. -
Thanks Stung!
In this case though, the file was a demuxed mpeg 2 (xvid conversion from FFMPEGX) and I was still having these problems! All I'm trying to do is join the two mpeg files but QuickTime refuses to allow me to copy either of them, it gives back a "no video track" or some such error. This is rather odd, since the video file seems to play just fine in QuickTime. DivX Doctor is reporting a problem with the files (aside from the AC3 soundtrack) and won't convert them, even though it will export the AC3. Now before somebody (Galactica) screems GIGO (Garbage in Garbage out), these files play absolutely beautifully in VLC.
All I want to do is join them, can somebody help?? -
Originally Posted by BDMTHRFKR
are you trying to imply something??
mpgtx wrap is a great app for adding two .mpeg files together, even muxed ones. just open the app, click JOIN, choose 1st one, choose 2nd one and click join
as long as they are of same frequenzy/resolution (etc) it should have no problem
likewise ffmpegx can add two mpeg's together. under tools go to VIDEO TOOLS
select 1st browse as 1st mpeg
select 2nd browse as 2nd mpeg
click JOIN under launch processing
again same thing... -
Garbage in = garbage out.
Dont forget that once you have joined your MPEGs, it might be necessary to demux the joined file and remux it.
This fixes timecode errors. -
thanks zerosix, dont know why i didnt put that in....
guess its the exam frizzle im feeling.
I have 4 exams tomorrow!!!!!!!
ahhhhhh!!!!!!
Excel basic question
By alintatoc in forum ComputerReplies: 2Last Post: 8th Dec 2011, 09:46 -
serious quicktime issue, basic MOV codec corrupt? mac
By aceswild in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 16:46 -
Basic video projector question
By jbaugh in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2009, 02:58 -
Basic FAVC Question
By Maikeru-sama in forum Authoring (DVD)Replies: 4Last Post: 10th May 2008, 10:56 -
Very Basic Authoring Question
By Seeker47 in forum Authoring (DVD)Replies: 7Last Post: 10th Jun 2007, 21:24
