Looking on EBAY the other day and came across a complete set of DVD's from a old TV show .They are only available as a complete set as Region 2 Pal .I live in North America region 1 and NTSC and REALLY want this complete set how can I convert Pal to NTSC . What type of software to use????? .What to do and use ??? .already know how to back up DVD movies so thats no proplem
You could start with this thread: https://www.videohelp.com/forum/viewtopic.php?t=180911
then do searches here on "Pal to NTSC"
as Baldrick said (in the above thread), it will require converting and reauthoring. A whole different ballgame than backing up.
Good luck :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Try here for info:
[/url]http://www.geocities.com/xesdeeni2001/StandardsConversion/ -
In my humble opinion, it just not worth neither the time nor effort involved converting these dvds. Go the cheaper route: find a dvd player with GOOD pal conversion. Some dvd players will play PAL, but sometimes it might look a bit 'off'.
I have a toshiba sd 3900 and it plays everydamnthing under the sun. Anamorphic widescreen conversion is EXCELLENT.
Don't bother with the whole conversion process as you most undoubtedly will become extremely frustrated as many before you have!
8) but thats just meBoy do I love my avatar!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
