Results 1 to 9 of 9
  1. All works fine, but i get purple colors over some frames, and a after few sec. they are gone, and come back again.....
    Converting to PAL, 25 fps. Running Win XP......
    Uninstall the Angelpotion codec.
    http://www.vcdhelp.com/faq.htm#angelpotion
  3. What if we never had the angel potion installed and just the nimo and divx 4.12, it seems that alot of people are having this problem but there is no clear solution, do you have any other ideas????
    Feb 2002
    canada
    hey all ...i tried almost every settings in the tmpg encoder;i still ge's t the purple effect....i tried it with version 2.00.29.113 and 2.52.34.129.. ..no difference hmmmm...
    Feb 2002
    canada
    i FINALLY got rid of the purple stuff!!!!1 check this out got to
    option/environmental setting/vfapi pluging=then put the priority
    of the direct show multimedia file reader to 2 or more and let the others at 0. bingo!!!
    (my initial setting was at -2)
    please reply if this did solve your purple problem.
  6. note, also do this too if u are having an error mesage in tmpgenc when importing file that says this-
    cannot open or unsupported
    Set that same filter to 5 and leave everything else the same
    ShiZZZoN PzN
    Everyday is another payday and I am one step closer to becoming the one.
    Feb 2002
    canada
    ok thanks sean madison!!
  8. Changing the enviromental settings seems to get rid of the purple parts coming in and out, however when i try to encode it freezes up with 2 seconds left, this has happened to me twice. One of the files still let me burn it but the other says it was corrupt. And when it freezes i get small vertical green bars at the top of my screen. Do you have any idea whats going on????
  9. I have purple in the original, for those of you that are getting purple haze it may be worth checking the original source file, I found the original to have the purple haze. May need to use some filters to filter it out, any ideas?
    Thx in advance.
    :) Gin0 :(
