for most of the higher up apps (in this case dvd Maestro), it doesn't require you to, but to have good menus with nice buttons, you usually have to make a psd file with Adode Photoshop. However since everyone does not have that program, their is a small work around.
You can do the same effects as Adode, by using 2 similar jpeg files instead. Just have one as the background and the other as the sub picture. Drag them both onto the same menu block and mess with the color mapping. I did one as a test and i was able to get it so that the text buttons only (actual letters not full block of words) were highlighted for buttons. i do have photoshop but sometimes making the layers with psd files gets to be a hassle, and it was good to see this method works fine as well ---have fun
JPEGS aren't too good for DVD, you're much better off using TIFFS for less artifacting.
Funny how "not everyone has" Photoshop, but they have DVD Maestro.... -
LOL i was just thinking about that when i received a reply to this post in my email.
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
need psd template for cd/dvd label
By wingfan in forum MediaReplies: 3Last Post: 22nd Dec 2008, 13:25 -
Bending a PSD in after effects
By sk8_aholic in forum EditingReplies: 2Last Post: 15th Dec 2008, 19:29 -
Jagged edges upon PSD inserting in PPro
By Vially in forum EditingReplies: 0Last Post: 12th Sep 2008, 16:34 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 19:28
