I just started using Cinema Craft Encoder to convert .avi files to vcd and svcd formats but to my chagrin, i learned that CCE does not multiplex audio and video.
Can anyone recommend efficient multiplexing software for use in conjunction with Cinema Craft Encoder?
If your audio values in the .AVI file are 41khz, why don't you encode straight to .MPG, rather than doing a secondary step of multiplexing?? Especially for those formats?
Use CBR encoding, with PS checked, and set your audio values..
But otherwise, yes, BBmpeg rocks for multiplexing......... -
If your encoding VCD, simply select MPEG-1 (SS : Video + Audio). You'll get a multiplexed MPEG-1 stream. There is an option for MPEG-2 to do this, but it forces you to use CBR encoding: MPEG-2 (PS : Video + Audio), which isn't always optimal. I always use multipass VBR to maximize quality and space. For those situations, I always use TMPGenc to do my multiplexing. I find the interface a bit easier than BBMpeg for simpler multiplexing jobs.
Impossible to see the future is. The Dark Side clouds everything...
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2012, 23:54 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 05:00 -
Multiplexing error using the film machine
By adidas36 in forum Video ConversionReplies: 4Last Post: 16th Nov 2010, 16:55 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 15:52 -
How much are DVD multiplexing and subtitle overhead?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 10th Jul 2009, 11:35
