Last time i posted an topic i asked how i could set subs to an movie and then convert it to MPEG with TMPGenc so i could place it on DVD....
I getted the answer that i should use FFDshow... I did that and i getted the subs under the movie but on 1/4 of the movie it began again on the begin and the other goes on... so i getted two subs under my movie.....
One started again and the other just goes true......
Do you know how i can repair this or do this good?
Don't use ffdshow.
Get your subs in .ssa format (or convert to it).
Use Avery Lees subtitler filter with VirtualDub (which overlays your subtitles on the source video), and frameserve to TMPGEnc.
/Mats -
Ok but when i'm saving the file with Virtualdub i'm getting an file from 13 GB........Originally Posted by mats.hogberg
Why is this why can't i just save it as an file of 700MB???? -
Use latest alpha ffdshow. Works fine here. Or instead of ffdshow try vobsub filter.
If you are using virtualdub, use the frameserver
www.dvdrhelp.com/virtualdubframeserve
Problems with Fraps and ffdshow
By Apexi in forum Newbie / General discussionsReplies: 0Last Post: 28th Jul 2009, 06:49 -
Problems with ffdshow, MPC and .mov videos
By ziptip in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2008, 05:14 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 23:19 -
FFDShow suggestions? - video playback problems
By Digiface in forum Software PlayingReplies: 6Last Post: 1st Aug 2007, 14:30 -
Massive ffdshow conversion problems
By Crazyj32 in forum Video ConversionReplies: 3Last Post: 25th May 2007, 13:52
