Can anyone suggest a progtam that will convert my Divx file with VBR audio. Tempeg wont do the job its fine with CBR but thats it.
Thanks Paul from London.
Results 1 to 9 of 9
Tempgenc Mod
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Sorry i should have said i want to convert to VCD format, will tempeg mod do the job
I'm trying to find the link for you. :c) Yes, I understand it works with vbr.
No wonder :cD I meant to write Virtualdub mod! :cD
Here is is: https://www.videohelp.com/tools?tool=332#comments
(sorry post title stuck in my head while typing)
Use it to frameserve to Tempgenc, if you like.There's no place like 127.0.0.1
I have tried Virtualdub mod it will convert both audio and video but it allways puts it out of sync
Oh, sorry. I use Ulead stuff as well as the temp/Vdub combo. Never came across any files they wouldn't take. And haven't had any synch problems.
Some other s/w I've tried would not live happily on my set-up.
They have trial versions if you want to have a go with them. :c)
Good luck.There's no place like 127.0.0.1
I looked at various forums and no one else seems to have this problem, Maybe i'm doing something wrong eleswhere. Thanks for you advice.
You're welcome. Have you done your searches here? There are tons & tons of audio/video synch threads running. Enough to keep anyone reading for a long. long time. :c)
I hope you find a reasonably easy solution. I know it can be maddening. :c)There's no place like 127.0.0.1
