  1. How can i create a menu in DVD Maestro where you can switch between different subtitle tracks or you can switch subtitles on/off?
    Thanx
  2. Nobody????!?!?
  3. Well,
    It depends upon how much info you need. Let's cut to the core. It's called stream pre-selection and is under the buttons tab of a menu.
    If you need more info (like how to create a button) experiment or read the manual. If you have no manual search this forum for yahoo maestro and read some info about guides/manual.
    I mean it in the nicest way.
  4. Thanx very much, mate. I think i know what you're talking about. Will experiment and post back the results.
    Cheers
