I bought Gangs of NY and i want to make a backup copy! The movie is on 2 discs so i ripped and converted each disc using DVDshrink. The total size of the both ripped discs is now 4464 MB! How do i put it on just one disc?
http://www.dvdshrink.info/re-author-v3beta5-advanced.php
I don't know if it will play the second title automatically
You can also use dvd2one.
dvd18(dual sided dvd) to one dvdr guides:
https://www.videohelp.com/guides.php?formatconversionselect=DVD18+to+one+DVDR
DVD ReMake Pro! join issue!!
By Shohag_ifas in forum Authoring (DVD)Replies: 7Last Post: 26th Dec 2010, 00:03 -
how to join 2 dvd folders without compromising quality
By flyerhigh in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2008, 01:35 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 22:21 -
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 11:58 -
How to join 2 DVD VOB files??
By hilario in forum EditingReplies: 5Last Post: 15th May 2007, 18:53
