Hey all. I've got a weird problem with TMPGENC. It's cutting out 20 mins of time in a DivX to SVCD converstion. I downloaded a series of TV episodes in DivX format, converted the first 4 with zero problems, started and finished on the 5th, only to find 20 minutes of the show missing. I ran the DivX show through VirtualDub looking for bad frames, and it found none. I double checked that the "source range" in TMPGENC wasn't set, and I restarted my computer and re-encoded the file 3 times, but it still leaves off 20 mins. Any ideas?
Sounds like EP #5 is corrupted and fixed already. Fixing seems to entail a 20 minute gap. This happens on P2P. You can try opening it in VDUB, using the advanced options and re-derive the keyframes.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
It didn't work. What else can I try? Re-encoding the whole thing? Is there some program that will just basicly copy the file and re-do the bad parts of the file? (if that's what the problem is)
Best & Fastest Tool To Cut An AVI, MP4 File In The Middle?
By onesikgypo in forum LinuxReplies: 3Last Post: 12th Oct 2013, 21:07 -
how to get rid of text in the middle or a avi video file?
By nsctsunomi in forum EditingReplies: 7Last Post: 22nd Nov 2010, 11:47 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19 -
How to chop out a section in middle of .flv file without reencoding
By Toastie in forum EditingReplies: 0Last Post: 15th Jul 2007, 19:54 -
How to insert a jpg file in the middle of an avi file?
By pmolson in forum Authoring (DVD)Replies: 7Last Post: 2nd Jul 2007, 03:26
