Hi produced the files from a toshiba DVD recorder in VRO format on a RAM disc and left unedited. Imported files into my PC and edited using MPEG2VCR. Saved file into MPEG2 format. File plays fine in Power DVD and WM9 and MPEG2VCR with audio. Using the above file produced a 55 sec sequence to be used as background for the motion menu, this also plays with audio as above. When i open the file to select it the Speaker icon is greyed out, this applies with the 55 sec segment or even the full 40min file. Pressing ahead and producing the DVD. Perfect, the menus look and work great, BUT no audio as the motion menu plays. Select a chapter, play, and works great. Anybody got any suggestions, have i missed something. On the menu display settings,motion tab i have selected the bgm option.
Many thanks for any suggestions
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 17:32 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 16:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37
