After buying my 106 burner I installed Nero 6.0.0.0 after that I checked the 'Choose Recorder' screen which told me the burner DOES NOT support buffer underrun protection (clicking on that screen “option>>” button revealed an gray 'buffer underrun' ALREADY MARKED option). Nero infotool proclaims my drive does possess buffer underrun protection.
I upgraded to v6.0.0.15 and Nero 'choose recorder' screen finally confirms my drive has this feature.
Here's the question: even though I setup Nero to utilize this measure (tried automatic and manual configuration) it disregards and does not use this protection !
While burning I never get the famous 'buffer underrun activated' (or something like that) - I always get that line when using my other burner (cdrw) with Nero. On top of that the log file confirms that buffer underrun protection was not used.
I also tried Nero 5.5.10.50 with the same results.
It's extremely important to me to be able to use this feature, for the obvious reasons - Please Advise.
Just wondering if the line that you are seeing in light gray is not saying : Show buffer underrun protection counter at the end of burn process. The Burner underrun counter is working for me on version 5.5.10.32 with that above line in light gray. I don't get that statement but the underrun counter is showing there.
No. the (not gray in my current 5.5.10.50 ver) option is 'buffer underrun protection enabled'.Originally Posted by j-a-w
Showbiz DVD2 vs 2.2.15.106 vhs capture problem
By zulubase in forum Capturing and VCRReplies: 0Last Post: 13th Feb 2010, 19:28 -
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
Another conundrum! How to burn Matroska HD files to DVD-R?
By expat in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2007, 15:02 -
Did "Good" media go bad -OR- DVD Recorder conundrum? Help!
By MrCreosote in forum MediaReplies: 9Last Post: 11th Sep 2007, 20:33 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
