I have question that is an off topic , but still needs to be addressed. I am going to buy the DVD burner , but I found out that my power supply only has four main connectors and they are used up. Has any of you used a cable splitter (Y cable) connecting two device from one of the main power connectors? I really do not want to buy another power supply or remove my existing burner. Would it be OK to use? Or, is there a risk I would be taking if I used it? Any feedback on this would be great...!
Not a problem. I've used lots of them. Just make sure your power supply is up to the increased load. Usually 300 watts is the recomended minimum if you have 2 hard drives and two burners. If you use a lower wattage, make sure it doesn't overheat.
Can I use 3.5db splitter for cable and internet?
By peggypwr1 in forum Newbie / General discussionsReplies: 13Last Post: 18th Apr 2012, 09:07 -
Composite cable splitter
By danielmak in forum Capturing and VCRReplies: 4Last Post: 8th May 2011, 05:12 -
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2010, 00:23 -
HDMI cable splitter
By snadge in forum DVB / IPTVReplies: 6Last Post: 21st Feb 2009, 11:24 -
can Analog Cable wire be connected to S-Video Connecter ?
By wolf2009 in forum Capturing and VCRReplies: 6Last Post: 5th Nov 2007, 16:55
