Hi
I've just downloaded svcd2dvd demo and after installation (including
MS .NET framework or stuff like that) with attempts to start the program, I
keep getting the following popup window with error message:
Application has generated an exception that could not be handled.
Process id=0x2dc (732), Thread id=0x238 (568)
Clock OK to terminate the application.
Click CANCEL to debug the application.
The image is attached as well.
The OS is Windows2000. Please CC reply to wongmc@yahoo.com.
MCW
Results 1 to 9 of 9
mcwGuest
Are you sure you are following the instructions properly? Especially #4:
SimonPGuest
Same problem here - just downloaded the demo version (2:30am UK time on 2nd October) and I get the same kind of error.
I unzipped the .EXE file in .ZIP file (I assume that's what you meant?) into the install directory but still get the same error.
I can only assume this is a bug in the new version posted, given that this has only been reported since 1st October?
Running Win2000 Pro here. -
simon,
can you tell me what sub folders you have to the following directory:
C:\windows\microsoft.net\framework
or (if win2k)
C:\winnt\microsoft.net\framework
thanksSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest
Sure thing:
C:\winnt\microsoft.net\framework\v1.0.3705
and
C:\winnt\microsoft.net\framework\v1.1.4322
plus assorted files, mostly dated 14/05/2002 and 20/02/2003. I installed it from Windows Update on 29/9/2003. -
Well after some research into the issue i think there is some .Net versioning nonsense going on. My advise is to re-install the .Net framework. This time can you install from : http://msdn.microsoft.com/library/default.asp?url=/downloads/list/netdevframework.asp
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
SimonPGuest
Ah-ha, that seems to have done it, thanks MiniMod!
Obviously it's worth including a note and that link so that others don't fall into the same trap.
(Interestingly, the only difference looking at it quickly is a config folder under the v1.1.4322 folder)
I'll test it a bit later but if it's half as good as it looks on the web page, I'll be registering it.
Cheers,
SimonP. -
8)
SimonPGuest
Just a quick follow up - it's working nicely now and the quality (particularly video) is stunning, much better than I was getting with NeroVision Express!
I just need to work out which of the niggles I have are a result of the Demo version's limitations and I'll be happy enough to part with some cash
Many thanks.
Vdubmod Crashes On Startup Kernel32 Error
By Konfusion in forum Video ConversionReplies: 10Last Post: 31st May 2009, 16:19 -
qustion about Windows startup error
By jimdagys in forum ComputerReplies: 4Last Post: 18th Apr 2008, 06:57 -
Fatal Error on Startup SVCD2DVD 2.5 (CRASH)
By jenevans33 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 16th Mar 2008, 11:06 -
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error on startup
By bush in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 22nd May 2007, 19:30
