I am looking for a online store that gives the most and best variety of cases..... i am lookin for some of the new fancy ones wit lights and crazy designs![]()
These people have quite a selection. Though, I have never ordered from them before because their reseller rating is piss poor (2.84 out of 10, find it here, but from their responses it looks like they are trying to improve). I suggest you look at their stock, find what you like and order one like it elsewhere, like at www.newegg.com but make your own call.
Newegg is a fantastic company that I have ordered from many times, but they have a poor browsing structure in my opinion. You kind of need to know what you want."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
i love those cases but i am scared to buy from there...... my thing is do most of the lights come with the kit ????? also when i go to computer show fans usually comes with the cases.... they are saying its optional
so is they sayin i gotta pay extra for the dam fan
I don't know about this particular store. But its very common that the case comes with one or two fans, but there is room for more. Mine for instance came with 2, but there is room for 5.Originally Posted by mol3000
They may be talking about the other spots that don't come with fans by default. Like I said, I don't know what colorcases.com does."A beginning is the time for taking the most delicate care that the balances are correct."
directron.com has alot. Also newegg.com has a few in there. There is a huge selection over at tigerdirect.com also.
Hope that helps. -
I purchased my case from Newegg.com but I think Tigerdirect.com has a larger selection.
SLICK RICK
Originally Posted by lordsmurf -
I'd suggest building your own. A friend of mine "added flare" to his computer like you're looking to do. Start with a decent case with a window (he used a piano black Antec case) and then add the lighting as you see fit. He put neon lights at the top of the case and the inside front to illuminate the system board. He got those LED fans for almost everything (there's even an LED heatsink fan for AGP cards) and put some chaser LEDs on the front of his case. If you're into that kinda thing I think it would be more fun making your own than buying one already decked out with holiday lights. Shop around at some of those sites and www.sidewindercomputers.com to get some ideas of what you can do with your case.
iPad cases
By ryangarfield in forum Off topicReplies: 0Last Post: 25th Jun 2010, 14:55 -
50 pk slim DVD cases
By zoobie in forum MediaReplies: 0Last Post: 14th Feb 2010, 19:53 -
iPhone cases recommendation please
By jmiller09 in forum Off topicReplies: 5Last Post: 31st Aug 2009, 05:51 -
swapped computer cases and now it wont power on
By rubberman in forum ComputerReplies: 12Last Post: 28th May 2009, 09:47 -
Bad DVD Cases?
By Nitro89 in forum MediaReplies: 3Last Post: 27th Feb 2009, 10:34
