I want to back up all files and setting (about 20gigs), I have only done so using an external hard drive and was wondering if people have had good success using DVDs, since it would take 4 or 5 discs worth?
thanks
Judging from you saying "settings", I have to assume that you are using some kind of backup program. Maybe you could mention which program it is? If you just mean select every file and copy it to the external hard drive, I don't see how using DVDs instead would cause a problem.
I know I have has a litle difficulty getting Norton Ghost to burn directly to CD-R. I normally just backup to a hard drive, then use nero to transfer the .gho files to a DVD. Works like a charm, if not a little slow."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Play full blu-ray movies on ps-3 from hard drive
By jim49 in forum Software PlayingReplies: 2Last Post: 7th Apr 2010, 19:54 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
miniDV tapes to hard drive. Uncompressed, full quality. How?
By vid83 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 16:43 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
Full Backup into a USB hard drive
By edong in forum ComputerReplies: 3Last Post: 11th Sep 2007, 16:19
