Has anyone had any experience comparing a dual processor setup compared to a single when it comes to rendering? I am thinking about upgrading my XP 2200 to a new motherboard with dual processors and was wondering if it sped up the process of rendering significantly. I would think it would help some with the load as well as the speed but would like to hear some first hand experiences.
2Busy
I guess for rendering you need plenty of CPU power, high buss speeds to transfer data, fast hard disks to read and write. For a fast rig I'd say running DUAL CPUs is a good idea. Using two drives would also be a good idea (read from one/write to the other).
I've got several rendering jobs laying around here to do, you upgrade and i'll send them over. ok
Good luck. -
If a rendering program can make use of dual processors, yes it will be faster. How much? I'm sure if you search around enough, somebody has done some testing. You would probably do just as well by using plenty of fast memory, a faster processor, faster bus speed and faster hard drives. Take a look at the computer profiles of the users of this site and I think you will get a good idea of what works for them.
m4a multi-track single file: how to split, tag and manage
By SeaFargo in forum AudioReplies: 0Last Post: 24th Feb 2012, 09:35 -
How i can make multi avchd dvd single layer discs with tsmuxer?
By fits79 in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Nov 2011, 08:09 -
What is a good processor or GPU for fast video rendering?
By johnharlin in forum ComputerReplies: 3Last Post: 2nd Feb 2011, 04:19 -
Joining Mixed Multi Angle Into Single VTS
By werdna1900 in forum Authoring (DVD)Replies: 1Last Post: 13th Jun 2009, 04:26 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32
