When I convert my Divx .avi file to SVCD .mpeg, the sound is in sync but starts to lose it as the movie proresses. By the time the movie is half way through, the audio sync is way out. Can anyone help with a simple solution that doesn't take hours?
save the audio of the divx into wav by using virtual dub. just open the video then file > save wav. after that when u encode just load the wav as the audio source. this method works for most divx movies.
I did this. Converted the audio to .wav using virtual dub. Then I used TMPGE, using the video as "video source" and the .wav file as "audio source". Now the sync problem is worse, and begins at the start of the movie.
I have the same problem, now i'm gonna try this:
Frameserving the divx file from VirtualDub to TMPGenc.
Are you using the new TMPGenc 2?
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 10:49 -
Audio Sync Problems
By Blue_3 in forum AudioReplies: 5Last Post: 10th Apr 2008, 19:17 -
Audio sync problems
By sticklebrick in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2007, 15:14 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 07:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 11:17
