Just wondering why the multiplexing part takes so long time...in Tmpgenc it's done in a minute?
Producing a MPEG-2 program stream of 775MB TMPGEnc mpeg tools simple multiplexer took 4 mins 57 seconds
same test using SVCD2DVD's multiplexor - mplex 4 mins 42 secs.
Both test done on:
HD fully defraged.Code:Operating System: WinXP SP1 CPU Speed: P4 2.8 GHz Harddrive space: 120 GB ATA 100 RAM Memory: 512 MB PC1066 Video Card: 128 MB DDR ATI Radeon 9700 Pro
Have you got a super optimised version of TMPGEnc?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Seems like it. A 163 MB mpeg 2 took 32s to complete in tmpgenc (normal multiplexing, not simple) and from svcd2dvd says "multiplexing elementry streams" until starting creating vobs it takes 4min 48s !
So it takes little more than 2 hours to complete a dvd.
amd athlon 1.4 ghz
512 ram
geforce 4 mx
win xp sp1
ata 100 hd -
Anyone else?
(FYI: it also adds navigation packs to the resultant mpeg which tmpgenc doesn't. But i would not expect that to be significant)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
well for me it takes over an hour about 1hour 20-30 mins... just depending if it is bins of mpegs....
but it has to demux, add nav points, reencode convert and reencode audio
and depending if its svcd2dvd or svcd2dvdmpg
it then remuxes the audio and video back together
one suggestion i have to speed this up is
give the option to use 2 or 3 hard drives....
use temp folders on them and all the demuxing would speed up if demuxed correctly to the different drives....
would hvae to think out the optimal way to do extract/demux for bin and also then mpgs only
or just extract bins then once mpegs start using the other hard drives....
or i might be faster to extract to one hard drive then move it back to same drive rather than extracting to same drive...
using 2 or more drives and them not being full and defragged would be the only speed increase. -
I aggree. Multiple drive support is the way forward. I will add it to the list.
videoredo takes too long to save ts
By codemaster in forum DVB / IPTVReplies: 6Last Post: 16th Mar 2012, 08:17 -
Ulead Video Studio 11+ DVD Burning takes very long time
By chrayf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2012, 15:43 -
AVI uploading to youtube takes too long, other file formats that cut time?
By jmcconnell86 in forum Video ConversionReplies: 1Last Post: 22nd Jul 2009, 19:50 -
Backing up HD takes too long?
By videobread in forum ComputerReplies: 4Last Post: 26th Jul 2008, 14:17 -
Media takes long time in intializing
By chankya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 00:10
