  1. I converted a .wmv into mpeg, but just in case..
    can this format be played on quicktime on a macintosh?
    i have to play this file onto a comp at my school, and they only have macs..
    they probably don't install codecs or nothin and.. just in case..
    does quicktime come pre-installed?>
    if not, what program comes pre-installed in .. i think something like os 9 ,(NOT OS X) for macs?
    will that program or quicktime be able to be play a mpeg 1 file?
    thx
    Feb 2003
    Bloomington-Normal
    qucktime can play MPEG1.
    Mar 2002
    Oswego, ny
    Can you share how you converted the wmv to mpeg1?
    It would be appreciated.
    Thanks!
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    quicktime comes preinstalled so after the conversion you should have no problems viewing it on those macs at school
    Nov 2003
    New New York, Year 3000
    Will the OS9 edition of Quicktime play MPG1 without the MPEG codec installed?
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
  6. Member galactica's Avatar
    Jan 2003
    mpeg1 should play natively. the codec is needed for mpeg2
    Jan 2004
    Finland
    Support for mpeg-1 has been in QT last ten years, no need to worry (unless U use really old QT, maybe version 2 or 3...).
    Jun 2001
    Silver Spring, MD USA
    Also to the original poster, if those school Macs use OS X, there is a Windows Media Player for OS X available. I wouldn't normally recommend using it but this would prevent you from having to convert things. I'm sure its on the Microsoft Mac web site. I installed it as it comes with MS Office v.X.
