I was trying out the trial version of snagit with a WMP window and only captured a black screen.
I seem to remember seeing here or elsewhere that it was related to some settings in the Video card settings. Possibly something to do with how it handles overlays?
I took a look in the display properties (AIW 7500A) and didn't see anything that looked like it would help
The rest of the screen captured Ok, But what good is it if the WMP part of the capture is blank?
I've tried searching here but no joy. I thought I'd seen it in relation to capturing video from something like WMP.
Results 1 to 11 of 11
You just need to disable hardware acceleration. :c)
Temporarily, of course.
You can do it without a snagging program in PowerDVD if you have that.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Yes, Power DVD will do it for you. :c) Go into Configuration - the hammer looking thingy - go to Video and un-tick Enable Hardware Acceleration.
Then use the little camera button for screengrabs. :c)
Re-tick Enable H.A., when you have all you need.
And.......... you're welcome. :c)There's no place like 127.0.0.1
Depends what you mean by screen cap. It will capture a frame of video, but it won't do a screen capture of your display including video playing on your desktop like this.
Yes, the above is for a screengrab of the video "screen". For full desktop screens that include video or any DirectX app (games) I use Hypercam DX.
:c)
Hey, I think I missed that version, Craig. :co
Thought I had them all!
:cDThere's no place like 127.0.0.1
I used snagit for the above capture, painshop pro will also work.
Hey, it's a good program! :cDOriginally Posted by Craig TuckerThere's no place like 127.0.0.1
Before I forget. For many things such as 1 frame screen caps I have used the Printscreen key. I then pasted into Wordpad or Word. I didn't even think of it for WMP video since I wanted clips from the video to be running for demo purposes.
I end up doing all kinds of things here at work since I'm a generalist (J.O.A.T) as well as computer repair & upgrade person.
JOAT = Jack of All Trades
Cheers
Roger the JOAT
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 18:34 -
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
AutoGK - portion of screen captured?
By torquay7 in forum DVD RippingReplies: 4Last Post: 29th Jan 2010, 10:19 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
