Hi.
I wonder if anybody has had the following problem after converting a avi file to dvd and burning.
On my Toshiba DVD player the burnt DVD picture seems to wrap itself horizontally across the TV screen. By this I mean what should be the right hand side 3 or 4 inches of the picture actually appears ont he left hand side of the screen. With the rest of the picture moving across three or 4 inches also.
I play the same DVD on my PS2 and another DVD player and they are both fine.
Has anybody else had this problem or kinow a solution?
Many thanks.
Are the PS2 and other DVD player on the same TV?
If so, than maybe your Toshiba DVD player can't read your media or your MPEG properly? was it DVD specs?
<< check the DVD Players Compatibility List to see probs others had with your player. -
Resolution of the MPEG is 480*480.
The PS2 and the other DVD player are both on different TV's?
Can the TV be an issue? -
Nothing to do with the TV.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15
