ok, it's not first time I have bad frames.
I am trying to split an .avi but can't because
I get the VBR message. Ok, first I should
extract .wav...no problem. I also have bad
frames and reading through guides (like King John's)
I used Vdub Mp3 because I get the VBR error
message. It crashes at a certain point...even
using the regular Vdub. I have figured out where
the bad frames are so I figured...let's just
delete manually from original .avi frame 15300 to 16100.
Now I get audio/video sync problem.
Any suggestions?
Thanks!
OK you have a bad place in the video
you have the saved WAV right ?
So load up the video and the audio separately with Audio-Wav audio
now fix the audio for the first part with Audio-Interleaving- Delay
save that part
do it again for the second half
save that part
you don't even have to delete bad frames
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
VDub, Key frames and syncing...
By takearushfan in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 14:04 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Vdub mod crashes
By tantal in forum Newbie / General discussionsReplies: 0Last Post: 19th Feb 2009, 13:47 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 11:03
