is there a way (using os x) to put multiple vcd onto one dvd without using the vcd>dvd botton (working only in the registered version)? Is it possible for example to author each vcd as dvd and then send all of them to burn in toast avoiding the conversion of the mpeg1 format?
Thanx
rimbaGuest
rimbaGuest
This doesn't work...
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 12:15 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29
