Hi,
I've just updated my OEM Ricoh RW5125A to firmware 1.64, but still can't get my DVD recorder to burn correctly !
Thank you for your help
Here is the log from Nero 6 :
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17/06/2003 15:25:04
Nero version: 6.0.0.15
Recorder: < DVD+RW RW5125> Version: 1.64 - HA 1 TA 1 - 6.0.0.15
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: < DVD+RW RW5125 >Version: 1.64 - HA 1 TA 1 - 6.0.0.15
=== Scsi-Device-Map ===
DiskPeripheral : IC35L090AVV207-0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : IBM-DJNA-372200 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : DVD+RW RW5125 atapi Port 1 ID 1 DMA: On
: EUSBMSD Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
DVD+RW RW5125 E: CDRom0
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 176MB (181156kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.9.2003
UDF/ISO compilation
15:56:09 #1 Phase 112 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation started
15:56:09 #2 Phase 114 File dlgbrnst.cpp, Line 1843
DVD-Video files reallocation completed (no file modified)
15:56:10 #3 Text 0 File Isodoc.cpp, Line 5878
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
15:56:10 #4 Phase 111 File dlgbrnst.cpp, Line 1843
DVD-Video files sorted
15:56:10 #5 Text 0 File Reader.cpp, Line 118
Reader running
15:56:10 #6 Text 0 File Writer.cpp, Line 127
Writer DVD+RW RW5125 running
15:56:10 #7 ISO9660GEN -11 File geniso.cpp, Line 3861
First writeable address = 0 (0x00000000)
15:56:10 #8 ISO9660GEN -11 File geniso.cpp, Line 3861
15:56:10 #9 Text 0 File Burncd.cpp, Line 3169
Turn on Disc-at-once, using DVD media
15:56:10 #10 Text 0 File DlgWaitCD.cpp, Line 230
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286415 (508:05.40)
15:56:10 #11 Text 0 File DlgWaitCD.cpp, Line 235
Write in overburning mode: FALSE
15:56:10 #12 Text 0 File DlgWaitCD.cpp, Line 1878
Recorder: DVD+RW RW5125, Media type: DVD+R
15:56:10 #13 Text 0 File DlgWaitCD.cpp, Line 393
>>> Protocol of DlgWaitCD activities: <<<
15:56:10 #14 Text 0 File ThreadedTransferInterface.cpp, Line 769
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286416 (2286416) = #2286416/508:5.41
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286416 blocks [ DVD+RW RW5125 ]
15:56:10 #15 Text 0 File ThreadedTransferInterface.cpp, Line 938
Prepare recorder [ DVD+RW RW5125 ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 4682887168, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286416 | lead-out | 1 | 0x00 | 0x41
15:56:10 #16 Phase 24 File dlgbrnst.cpp, Line 1843
Caching of files started
15:56:10 #17 Phase 25 File dlgbrnst.cpp, Line 1843
Caching of files completed
15:56:11 #18 Phase 36 File dlgbrnst.cpp, Line 1843
Burn process started at 2.4x (3*312 KB/s)
15:56:11 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2136
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:56:11 #20 SCSI -1066 File Cdrdrv.cpp, Line 1203
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03A25000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x24 0x00
15:56:11 #21 Text 0 File DVDPlusRW.cpp, Line 1491
Set Booktype to DVD+R (10), set mode 'drive EEPROM' (0) on DVD+R media, return: 0 -> OK
15:56:11 #22 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 23:51,444 (1431444ms) -> OK
15:56:11 #23 Text 0 File DVDPlusRW.cpp, Line 555
Start write address at LBA 0
DVD high compatibility mode: Yes
15:56:56 #24 SCSI -400 File Cdrdrv.cpp, Line 1411
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03F30000
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x91
Sense Qual: 0xC4
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x91 0xC4
15:56:56 #25 CDR -400 File Writer.cpp, Line 335
Unspecified target error
15:56:56 #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:56:56 #27 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
15:56:57 #28 Phase 127 File dlgbrnst.cpp, Line 1843
Generating DVD high compatibility borders
15:56:57 #29 SCSI -1066 File Cdrdrv.cpp, Line 1203
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
15:56:57 #30 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
15:56:57 #31 Phase 129 File dlgbrnst.cpp, Line 1843
Generating DVD borders completed successfully
15:56:57 #32 Text 0 File DVDPlusRW.cpp, Line 1491
Set Booktype to DVD+RW (9), set mode 'drive EEPROM' (0) on DVD+R media, return: 0 -> OK
15:56:57 #33 Text 0 File dlgbrnst.cpp, Line 1703
15:56:57 #34 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 2.4x (3*312 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 10:27:50 (Adapter
driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Was it OK with 1.51?
Tried RecordNow?
Tried another media type?You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I had an older firmware (something like 1.34), and it didn't work then.
It just stopped working one day.
It is in fact an OEM from Memup (french company).
The drive is a Ricoh RW5125A
What is RecordNow ?
Tried Verbatim DVD+R 2.4x Certified
and Traxdata DVD+R
I can burn DVD+RW (Verbatim) and CDRW or CDR
Thanks for your help
Originally Posted by tompika -
1. Download the FW and flash it again with 1.64
2. Check your computer system
3. Defrag your HDD
4. Reinstall Nero. Try burning
3. Get RecordNow MAX 30 days trial, install the px engine update
http://www.stompinc.com/trial/index.phtml?stp
http://support.sonic.com/Downloads/engine.asp
Try burning
4. Get the drive repaired or buy another one
In this orderYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
You are getting a hardware error so I would say that it is probably a bad drive.
RG
ripped DVD plays, but won't burn
By Yes, me in forum MacReplies: 7Last Post: 3rd Sep 2009, 04:58 -
Some Avi files will burn on dvd, others won't??????
By Qvezzy in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:47 -
PGCEdit won't burn DVD
By Weapon-X in forum Authoring (DVD)Replies: 9Last Post: 27th May 2008, 07:18 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 21:41 -
DVD Won't Burn
By wwpranma in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 04:32
