I have a problem in Virtual Dub, and hope someone can help me... When I try to open a Mpeg video file, it shows the following error: "MPEG Import Filter: pack synchronization error".
How can I fix this problem?
Thanks in advance
Actually I have had this a couple of times.
It usually only occurs in mpeg1 files - well that's all I've seen it in
And always things I have downloaded - I think it's a corrupt header or similar.
by all means try virtualdub Mod - it's much better than the original version but I don't think it will help in this problem.
You might to re-stream or repacketise your mpeg file - although be prepared for the fact it's damaged beyond repair -
If it is an mpeg 1 you could try remuxing it in tmpgenc.
virtualdub-mpeg2(version1.5.3build16401) also works well with mpeg/mpeg2 but a real mpeg editor would be the better solution. Like maybe mpeg2vcr.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 18:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
