I have some home moves (no not that type) that I would like to put on dvd. My question is what will a Normal DVD burner read. How do I have to put the files onto the disk. I have ezcd-dvd studio but seemed to fail using it my dvd player just gets a read error.
I do have a ts_video folder what format goes in that. and where does audio go. what is the easyest/best tool to do this.
I am really just trying to create a format that will work on most peoples dvd player.
Thanks for any help.
-=Jason=-
www.programmergeek.com -
Your responce requires about 4 pages. Instead your going to get a dozen people telling you to read the guides.
Read the guides, then ask specific questions.
You going to hit between 50% and 75% of the DVD players out there for compatability. Sorry, that's just the way it is(didn't even bring up +r versus -r versus SVCD/CVD/KVCD/VCD). Generally speaking the cheaper models will play anything, go figure.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Help, Newbe has basic question.
https://www.videohelp.com/forum/viewtopic.php?t=180555Want my help? Ask here! (not via PM!)
Originally Posted by ProgrammergeekOriginally Posted by ProgrammergeekYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
If your files aren't in the mpeg2 DVD compliant format then they are first going to have to be encoded to that format. Programs like TMPG or Main Concept can do that for you. Then the mpeg2 file you created needs to be authored. This means creating a navigation file for your DVD player and breaking the mpeg2 file you created into smaller units called VOBs. Something like DVD Lab or Ulead DVD Movie Factory will do this for you. Then you take the empty AUDIO_TS folder and the VIDEO_TS folder created by the authoring program and burn them to disc. Guides on how to do all of this are on the left.
Excel basic question
By alintatoc in forum ComputerReplies: 2Last Post: 8th Dec 2011, 09:46 -
Basic Video Encoding Question
By crosen in forum Newbie / General discussionsReplies: 9Last Post: 24th Oct 2009, 20:48 -
Basic FAVC Question
By Maikeru-sama in forum Authoring (DVD)Replies: 4Last Post: 10th May 2008, 10:56 -
newbe needs help with bad video
By Bulldog57 in forum RestorationReplies: 6Last Post: 14th Aug 2007, 16:59 -
Very Basic Authoring Question
By Seeker47 in forum Authoring (DVD)Replies: 7Last Post: 10th Jun 2007, 21:24
