OK I have been making some images to put music over in VS7. I created the images in Photoshop, and I created them 1024 X 576 (pixels/inch) and the Resolution is 600 pixels/inch and the colours are RGB colouring.
Now when i import them into VS 7 they are all pixelated. Is this because it dosent want to preview at the highest quality so the computer can still operate fast?
And does anyone have any tips on what image files to use, should I save them as a Jpeg EPS Tiff what should I do to get the best quality? lower resolution or higher resolution?
Any tips would be greatly appreciated!!!!
What are you trying to make? If you are making a VCD with the Ulead VS7 timeline then they will come out rendered to 352x240 (NTSC). If making DVD they will render to 720x480 (NTSC).
I use JPG and they are fine for DVD but Im not sure about other formats and quality differences. -
In Ulead VideoStudio 7.01, click FILE > PREFERENCES > QUALITY & DURATION tab.Originally Posted by JSGTPD
What do you have selected in the IMAGE RESAMPLING OPTION drop-down list?
Jerry Jones
http://www.jonesgroup.net -
I am making a commercial for a loop dvd that plays movie trailers in my video store. So I need really good quality.
I have changed the setting t6o "Best"
And in the drop down menu I have tried all 3 settings but I keep it on "Keep Aspect Ratio"
Any tips? The quality looks like crap!
Virtual Dub converted files poor quality.
By stark88 in forum Video ConversionReplies: 4Last Post: 8th May 2011, 23:39 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Won't create .img disk image
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 13th Feb 2008, 11:02 -
poor image quality WINXP MCE -> Projector
By akuma548 in forum Media Center PC / MediaCentersReplies: 8Last Post: 11th Aug 2007, 16:23 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 20:28
