In this program I want to convert an AVI to DVD (obviously) but I want to use 352x480 as the res, instead of 720x480. In the "resize to" option, I can only select DVD 720x480 or CVD 352x480. If I choose CVD my encoded MPEG uses a lower bitrate than it should and it adds borders to an anamorphic video (i.e it appears squashed).
Is it possible to get AVI2DVD to work properly with 352x480 DVD? Or am I stuck with 720x480?
Main reason I wanted 352x480 was to get a better picture for my bitrate. I was going to use a 4.4Mbps average - is this OK for 720x480? The video has quite a bit of action in it. But also a 352x480 video takes less time to encode :P
What should I do?
use tmpgenc to convert your avi to a non-std vcd you can even use higher bitrates if your player can stand it.
Vcd 352x288 1150cbr (or go higher) :PCorned beef is now made to a higher standard than at any time in history.
Originally Posted by RabidDog
AVI2DVD problem
By Electroniks in forum Video ConversionReplies: 3Last Post: 26th Aug 2008, 14:41 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 14:11 -
avi2dvd problem
By cr2007 in forum AudioReplies: 3Last Post: 17th Nov 2007, 07:49 -
avi2dvd problem again..
By aruwin in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 02:12 -
AVI2DVD Problem
By gonwk in forum DVD RippingReplies: 1Last Post: 12th May 2007, 22:08
