I need to diplay the video clip time while the video plays in my rendered movie (at the bottom somewhere), often this is seen on unfinished video that still needs editing. This can also be seen on many screentests that do not appear in finished movies. I'm using Adobe Premiere 6.5, I thought a filter or effect could be used to do this, but I haven't found one yet. If anyone knows how to do this, please let me know how. Also, I can use Adobe After Effects, can this be done here as well, or as a substitute to Premiere?
mojo
in after effects - effects -> video -> timecode
drop it on your comp window and set it up on how you want it displayed ..
and make sure you select to "encode and display""Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
HD PVR Not Displaying in HD.
By FinalGypsy in forum Capturing and VCRReplies: 11Last Post: 4th Feb 2010, 18:05 -
Adobe Premiere Elements 2.0 and 4.0 installed at the same time
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 26th Aug 2009, 01:21 -
iTunes 8 displaying a few songs with the wrong run time
By Nintendo Fan in forum ComputerReplies: 26Last Post: 8th Jul 2009, 18:34 -
displaying foreign letters
By aruwin in forum ComputerReplies: 5Last Post: 20th Apr 2009, 10:01 -
problem displaying video on TV
By namsilat in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2008, 18:51
