I know even the subject line might cause religious wars. TMPGEnc has always been the holy grail of VCD file conversion software. I've used it for a couple of years now too but am just fed up with all the bugs.
I've got a bunch of little music video MPGs that are in various odd pallates of frame rate, streaming audio, NTSC/PAL, etc. I'm trying to load up a TMPGEnc batch file so it can convert them all to more sane formats. Unfortunately if I pick up one that causes TMPGEnc to crash, I have to click through scores of little "runtime error boxes". Afterwards if I can get TMPGEnc to even restart I have to reset the stream type (NTSC(film)) and output directories. It just feels like the source code to this thing is a house of cards.
TMPGEnc and I have had one of those barely functional relationships over the last few years but now I think its time I started looking for a newer, stronger, more robust and attractive replacement so I can kick TMPGEnc out!
Any ideas?
Results 1 to 9 of 9
maybe Mainconcept MPEG Encoder
Definitely look into Cinema Craft Encoder (CCE) -
Top quality for encodeing to mpeg1 VCD format. For DVD I stick with the regular retail programs like Ulead MediaStudio or others with broad capabilities.
I like it, I liked the name better when it was called psunami (however it's spelled)
"Terminated!" :firing: -
Tsunami MPG Encoder
You get what you pay for.
As far as converting assorted music videos.....come on! Your serious? Your batch encoding 20 fps 400x300 PAL videos in RM and MOV and wondering why you have crashes in batch encoding? You have to juggle the enviromental settings based on video type, or it will crash.
I did pay for TMPG, and although not the fastest, it has worked for me. CCE never seems to work (that is none of the trials let you actually use the ******* thing, no opening/saving ECL files). I guess that leaves 1 or 2 others out there, but same thing, they don't work with other apps.
I gave up doing MPEG2 by hand (that is each step manually) a long time ago, and I'm not going back to command lines now.......To Be, Or, Not To Be, That, Is The Gazorgan Plan
VCR replacement
By yuhr in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 22:10 -
VideoRedo Replacement
By seymoria in forum EditingReplies: 9Last Post: 22nd May 2011, 15:47 -
Looking for a replacement
By Peacedog in forum DVD & Blu-ray RecordersReplies: 7Last Post: 2nd May 2009, 19:13 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
Stage6 Replacement
By acid_burn in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Nov 2008, 02:09
