Is there a way to save all your settings to a template?
When I save my settings it saves teh file I am converting and the name I'm converting it to. If I browse to a new file to convert, it reverts back to the original settings.
If I load the template again, back to the original file I was converting. Very annoying and useless.
Any suggestions?
LS
Did a 2hr 43minute movie in VCD VBR in 1hr 48m.
Results 1 to 9 of 9
Any suggestions? If I can get past this very annoying feature, I would switch soley to MC.
LS -
OPTIONS-->USE LAST PROFILE AS DEFAULT
I think is what your after.
BTW Did a 1hr 51minute movie in DVD(720x480) VBR in 1hr 20m - nice! -
not quite sure your problem .. you can create a new template very easy ..
then if you want -- edit it in notepad ..
it will be always on the drop down list - but if you change a setting - it will just show mpeg2 in gthe drop down instead-- which is ok (and true) ..
the profile (template) option is under "options" -> "save settings as profile"
i think you are just saving a project file -- which is useless unless you plan on re-doing something later .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
@BJ_M yep that's it - forgot to mention that...doh!
Bingo! That was it.Originally Posted by BJ_M
Thanks...
Does MC 1.4 process AC3 audio?
LS -
no -- it does not do ac3 encoding
It will accept an ac3 file as audio INPUT though (and handels vbr mp3 audio very wel too)Does MC 1.4 process AC3 audio?
I have a AVI file with AC3 audio and it plays fine on MediapLayer. When I encode it with MC 1.4 there is no sound.Originally Posted by Roderz
If I try to extract the audio with VDMod, it errors out even after running a DivFix on the file.
I'll try goldwave and make a seperate audio file with it and see how it goes.
Thanks!!
LS
2 Questions regarding Templates for DVDs
By eduard879 in forum Authoring (DVD)Replies: 1Last Post: 9th Mar 2011, 09:01 -
AVISynth Templates in VDM
By adalect in forum Newbie / General discussionsReplies: 2Last Post: 19th Apr 2010, 22:39 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 02:16 -
DVD Templates and encoding
By Canadian* in forum Authoring (DVD)Replies: 2Last Post: 24th Sep 2007, 19:11 -
How To Install Templates into StaxRip
By Trac in forum User guidesReplies: 0Last Post: 7th Jul 2007, 02:23
