Results 1 to 10 of 10
  1. i am tryin to burn this movie using the latest version of Nero and i used the dvd-video and the dvd-rom(udf/iso) settings and when i put both dvds in my dvd player, it wont play at all. i have the optorite dvd burner and using memorex dvd-r 4x dvds to burn. is there any other way to fix this problem? any other programs i should use?
    thanks
  2. Does the player detect the disc and THEN not play ?
    Could be a media problem, or even that your player will not play -R / +R. Not all do...
  3. when i put in the dvd in my player, it will jus say "search" but never does anything else. the dvd works fine on my computer. it might be the media because i used verbatim and it works fine. i can only write at 2x with these memorex and 4x with the verbatim dvds.. are there any other programs i can use besides nero? you think it might be that i have the new nero version also? i was using nero v5 something..
  4. ichiro829, you could give burnatonce (a free proggy) a try.
    http://www.burnatonce.com
    Guide: http://www.dvdshrink.info/burnatonce.php
    ddlooping
    For DVD Shrink guides & goodies: DVDShrink.info
    My "other" site: Teaching-Tools
  5. i have the VIDEO_TS folder with all the files already on my computer, im lookin for a program that all i have to do is burn the VIDEO_TS folder on the dvd and it will play on my dvd player. i did it that way with my verbartim dvds with nero and it worked fine. anybody know a site that has all the older versions of nero?
  6. just out of curiousity, did you put an AUDIO_TS folder in with the compliation.....Even though its empty its still required because of compatibility...SasArchiver...i use nero it works fine...
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
  7. yea i also put the AUDIO_TS folder in there, what version of nero are you using?
  8. im using ahead nero 6.0.0.0...sasArchiver
    Jul 2003
    Cary, NC, USA
    I had similar problems with my Optorite burner (disks used: Ritek 4x DVD-Rs)
    Other people are also complaining about the burner. In my case the disks do not play on Norcent DP300.
    People are suggesting that on this burner, use DVD+R and not DVD-R till the firmware is fixed. There might be a workaround also for DVD-Rs:
    https://www.videohelp.com/forum/viewtopic.php?t=180806
