My dad has a dv camcorder and wants to know if there is anyway i can put it onmy computer and encode it to vcd i am gonna use tmpg to encode it if i ever get it on my computer. Does anyone know how i can get it on my PC?
In my opinion the VCD format sucks ass for quality picture. You might as well save yourself the time and trouble and just record the original to a VHS video.
If you really want to do this you should consider getting a DVD Burner and put it on a DVD-R but if that isn't an option then look into doing a SVCD or CVD as the quality will be MUCH better than a VCD.
The trick of course is that not all stand alone DVD players can handle SVCD or CVD whereas almost all will play back a VCD.
In my experience CVD seems to be more compatible than SVCD.
Best HD camcorder that can record onto tape?
By alexh110 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 10th Oct 2011, 10:20 -
Convert analogue camcorder tape to pc
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 22:59 -
Get video from tape camcorder onto PC
By krabople in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2010, 17:23 -
Get tape out of dead camcorder
By mickseven in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2009, 15:21 -
Broken camcorder or damaged tape?
By eliw777 in forum Capturing and VCRReplies: 11Last Post: 29th Dec 2008, 00:09
